CW 10.1 can not close and does not remember last workspace
792 次查看
barbercolman
HI
Each time I start CW 10.1 I have change to the correct workspace even If I have the use as default checked. Any idea what is wrong? Also Windows sometines complains the CW does not exit.
标签 (1)
1 回复
651 次查看
CrasyCat
Specialist III
Hello
Are you using the tools on a Windows 7 host?
If this is the case can you try to uninstall CodeWarrior and install it outside of the Program Files  folder.
For instance using C:\Freescale as root instead of C:\Program Files (x86)\Freescale.
It looks like you do not have write access to the CodeWarrior installation directory.
CrasyCat
