CODE COMPATIBILITY FOR MPC5200B
1,795 次查看
yuva
I generated code for a subsystem in simulink for MPC555 target. I need to run a PIL simulation on MPC5200B evaluation board. Can anyone suggest me where i can modify the generated so that i can compile the code using codewarrior 8.1.
767 次查看
Voxan
Hi there,
is there anyway to have simulink to generate high level code??
If not I would recommend to go throught the 2 processor instruction set, notice any difference and then check you simulink output...
Hope this helps...
