Bug Report: CW10 - Deleting .h file does not clear up reference in SourceFile.obj
mykepredko
To the powers that be and anybody that sees this problem:
I've found that when I delete a .h file in CW10 and then rebuild, I get an error saying that the .h file is expected in SourceFile.obj (SourceFile being whatever .c the .h was originally loaded into).
To correct the problem, I go into the SourceFile.d file found in BoardType_Int_Flash_Debug|Release - Sources and delete the reference.
In changing/saving the SourceFile.d, I get the message saying that it is a derived file, am I sure I want to do this and I say "Yes".
After doing this, the project builds without any issues.
myke
CrasyCat
Specialist III
Hello
An easier way to fix that is to click right on the project name in CodeWarrior project window and select "Clean Project".
This will remove all intermediate .d files and you should be able to build after that.
CrasyCat
CrasyCat
Specialist III
Hello
CrasyCat
mykepredko
Thanx for the pointer!
myke
