56800e  CW "Files missing from hierarchy"
3,088 次查看
AgentK
and CW boots, with a greyed caption bar & ignores all mouse activity. Anybody know why this happens and how to sort it?
Message Edited by CrasyCat on 2007-04-13 11:20 AM
标签 (1)
标记 (1)
3 回复数
1,258 次查看
AgentK
Thanks for the quick reply - everybody else that I asked seems to be out of the office!
CW 7.3 56800e under XP.
(I had to save the xml's as txt's to get them attached.)
1,258 次查看
CrasyCat
Specialist III
Hello
I am not an expert in Hawk, but I know we have trouble running CodeWarrior on Win XP 64-bit.
Are you using a 32-bit or 64-bit version of XP?
Also do you have a file license.dat in your CW root installation directory?
CrasyCat
1,258 次查看
CrasyCat
Specialist III
Hello
-Which CPU are you targeting( HC08, HC12, Coldfire, ...)?
-Which version of CodeWarrior are you using?
  Can you send me the .xml file in the {Install}\Bin\Plugins\Support\Products directory.
-Which OS are you running on the Host?
CrasyCat
