What about a DSP56303?
kenc wrote:
I'm not sure if multi-device chains are tested or fully supported by the 56800 tools . . .
rocco wrote:
I recently sent to fab a board with a DSP56303 in front of an FPGA in a JTAG chain. I found nothing in the documentation that said I shouldn't do this. Will I not be able to debug?
#control board JTAG initialization file for Metroworks Code Warrior#8051F120Generic 16 1 0xFFFF#EPLD1Generic 10 1 0x3FF#EPLD2Generic 10 1 0x3FF#EPLD3Generic 10 1 0x3FF#DSPDSP56800
When I attempt to load this file for mult-core debugging, I get no confirmation that it was parsed correctly. If I exit out of the dialog where the file is selected, then re-enter the dialog, the checkbox for multi-core debuggin is unchecked. I assume this means the jtag configuration file did not take. How do I get this to work?
I need the following from my JTAG tools for the 56F8322:
Message Edited by JimmyMood on 2006-08-23 04:45 PM
