不能安装codewarrior2.9,提示我没有.msi文件
三火同学
如图所示,安装不了codewarrior ,请问如何解决
stanish
version you are trying to install is pretty old.
I suspect the installer hasn't been tested using newer OSes.
Could you indicate what is your OS?
Could you possibly try to install the latest "Classic"version: CodeWArrior for MPC55xx/56xx v2.10
or Eclipse version v11.x (that supports just MPC56xx/57xx families) instead.
If you intend on using v2.9 I'd suggest you to install into a Virtual Machine using supported version of Windows OS.
C. Supported Operating Systems
* Windows XP Pro Edition (32-bit)
* Windows XP Pro Edition (64-bit)
* Windows Vista Home Premium Edition (32-bit)
* Windows Vista Home Premium Edition (64-bit)
* Windows Vista Business Edition (32-bit)
* Windows Vista Business Edition (64-bit)
* Windows 7 Home Premium Edition (32-bit)
* Windows 7 Home Premium Edition (64-bit)
* Windows 7 Professional (32-bit)
* Windows 7 Professional (64-bit)
Hope it helps.
Stan
