@jennymplunkett from the Arm mbed team just posted a great tutorial using the LPCXpresso54608 touch screen on her blog... check it out at https://os.mbed.com/blog/entry/How-to-LPCXpresso54608-touch-panel/
Same code shown will also run on LPCXpresso54628.
Thanks Jenny!
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
