questions in procedures transplant MC68HC908QT4 to MC9S08QD4
slx123slx
Procedures transplant MC68HC908QT4 to MC9S08QD4, PWM settings 908QT4 function bit TSC0_CH0MAX set 0,1 QD4 corresponding bit, how to solve, guidance.
#if PWM_POLARITY == PWM_NEG /* negative PWM polarity */
                if (AppControl.B.FullOpen == 1)     /* PWM fully open, duty cycle set to 0% */
                    if (AppControl.B.ZeroDuty == 0)
                        AppControl.B.ZeroDuty = 1;   /* zero duty cycle on */
                      TSC0_CH0MAX=0; //  MC9S08QD4    TPMC0V = 0; use MIN20  ?
                else
                    if (AppControl.B.ZeroDuty == 1)
                        AppControl.B.ZeroDuty = 0; /* zero duty cycle off */
                        TSC0_CH0MAX=1;// MC9S08QD4  TPMC0V = 220;  use  MAX 200  ?
            #else                       /* positive PWM polarity */
                if (AppControl.B.FullOpen == 1)     /* PWM fully open, duty cycle set to 100% */
                    if (AppControl.B.MaxDuty == 0)
                        AppControl.B.MaxDuty = 1;   /* Max duty cycle on */
                        TSC0_CH0MAX=0;
                else
                    if (AppControl.B.MaxDuty == 1)
                        AppControl.B.MaxDuty = 0; /* Max duty cycle off */
                       TSC0_CH0MAX=1;
            #endif
