i need someone to recomend me for a BDM tool for CW V3.0
yshmuly
im tired of that OSBDM and looking for something up to $100
USB is prefered an that will be compatible with codewarrior v3.0
and as much as can MCU's and common one
eckhard
I used v3.1 and just upgraded to v5.0.
So for now i use both versions, but v5.0 seems to be fine.
Eckhard
peg
Senior Contributor IV
I have only used it with V5 because I understood you needed V5 to be able to use the "set gdi" command. So I haven't tried any lower versions. If I get a chance I will try it with V3.1. But I don't have (or want to download) V3.0.
BR Peg
yshmuly
by the way what version of codewarrior do use?
yshmuly
i used the schematics published on this forum but changed the smd with regular parts. the usb flashing wasnt succeded and i did it with mon08 (wich i had to build). after programming it still didnt work so i figured some resistors are not needed. and now somties it work (partially) and sometimes not and i dont want to spend more time with it. it is not well implemented in CW it looks like a patch on it. but thid is only my experience with it maby someone had different.
but now nobody will answer my question (about the BDM in the firs threde)
eckhard
I´am going to build an OSBDM too, whats yor problem with it. Could you please explain whats wrong with OSBDM for you.
Eckhard
