how preserve eeprom data - 9S08DZ60
2,564 次查看
cocheca
Hello !
I´m working with the board DEMO9S08DZ60 and I need preserve the eeprom data when I reprogram the project.
I try to SET in the programmer -> MultilinkCyclonePro/ AdvancedProgramming / Always Preserve All EEPROM Data or same range of them .. but DIDN´T WORK !!!
What i need to do ?
I try with the forum of P&E ... but, it don´t work or i can´t do a search !!
Excuse me for my english.
Thanks, Jose.-
4 回复数
1,206 次查看
Lundin
Senior Contributor IV
It works for me, using CW6.0. If you are using the same version, you should post a service request at the Freescale site.
1,206 次查看
Ake
Now I am not a C-guru at all, I have not tried it, but I would use
const unsigned char data[64] @EEROM
and then use.
But as I said, I haven't tried it myself, so it might not work at all.
Ake
1,206 次查看
Lundin
He is asking for how to prevent the debugger from erasing the eeprom each time he loads the project.
1,206 次查看
cocheca
Hy Lundin,
You have reason ... the problem is how prevent the debbuger to erase the eeprom.
I found this theard http://forums.freescale.com/freescale/board/message?board.id=CW816COMM&message.id=1112&query.id=1028...
it´s explain how edit the xxx.S8P file to preserve the EEPROM !!! That works for me !!!
But, I wiil try again with the setting of MultilinkCyclonePro/ AdvancedProgramming
Thanks for your help.
Regards, Jose.-
