a SCI problem of 1321XNSK BDM
2,572 次查看
bunrichard
Hi everyone,
  I have a 1321XNSK BDM Network Starter kit in my hand and I am trying to test the fonctions for PAN and UART. My problem is that when I connected the Coordinator and the End Device with USB cables, I could easily exchange datas or files between them by using the hyper terminal software like Tera Term. But when I connected the Coordinator with the cable of RS232, nothing is shown in the hyper terminal window and no data could be exchanged between the Coordinator and the End Device. Even when I press the Reset button in the board of the Coordinator, a pre-programmed message could not be shown neither.
  Could you please give me a hint in order that I could find out a solution. I am looking for your response and thank you so much for your attention.
标签 (1)
3 回复数
1,231 次查看
bunrichard
thank you so much Fire!!
1,231 次查看
fire
With 13213 you can not use Rs232.
1,231 次查看
UC3MZigbeeGroup
If we cannot use RS232 in the NCB of this kit (1321XNSK-BDM), why does it have the interface RS232? We have the same problem mentioned above and would be great if you give us a wired explanation. Thank you very much.
