Zip file for AN3942 Application Note
4,133 次查看
amalmathewtech
Hello ,
          I am looking for the  zip file which is mentioned in the Document AN3942.
https://www.nxp.com/docs/en/application-note/AN3942.pdf
The link provided for zip file on the above mentioned has expired.
Can any one help on this.
4,117 次查看
vicentegomez
I will send it directly to you
Have a good day.
4 回复数
4,109 次查看
amalmathewtech
Thank you  very much @vicentegomez
4,118 次查看
vicentegomez
Have a good day.
2,115 次查看
gabtie
Could I also have the zip file of the AN3942SW? @vicentegomez @amalmathewtech
3,523 次查看
MHolmes
Is it possible to also get this zip file?
