Why my sample project xBee doesn't compile ?
2,551 次查看
florianguillema
I want to program on a xBee S2C module on CodeWarrior 10.2 and with the Programmable xBee SDK.
But I can't compile a sample project and I got that :
Invoking: HCS08 Compiler
"C:/Freescale/CW MCU v10.2/MCU/prog/chc08" -ArgFile"Sources/pan/zigbee/zigbee_zcl.args" -ObjN="Sources/pan/zigbee/zigbee_zcl_c.obj" "C:/Program Files/Digi/PXBee/v1.5/pxbee_api/1.5.5/src/pan/zigbee/zigbee_zcl.c" -Lm="Sources/pan/zigbee/zigbee_zcl_c.d" -LmCfg=xilmou
FATAL C50: Input file '-ObjN=Sources/pan/zigbee/zcl_client_c.obj' not found
I got this for a few files... I don't understand why cause I just followed this example :
Digi XBee® Examples & Guides | Step-by-step Tutorials for Implementing XBee® Wireless Modules in Ele...
Thanks for your help!
4 回复数
2,075 次查看
florianguillema
Today, I found the problem... I just found in renaming C:\CYGWIN in C:\CYGWIN-1 that the problem is solved.
Can anyone tell me a better solution than renaming the CYGWIN directory, please ?!?
Thanks!
2,075 次查看
florianguillema
Up please ^^
2,075 次查看
florianguillema
Oh and I get that for each file not found :
mingw32-make: *** [Sources/pan/zigbee/zcl_client_c.obj] Error 1
Hope it will be helpful ^^
2,075 次查看
Wlodek_D_
Senior Contributor II
Thank you for your post, however please consider moving it to the right community place (e.g. CodeWarrior Development Tools or 8-bit Microcontrollers) to get it visible for active members.
For details please see general advice Where to post a Discussion?
Thank you for using Freescale Community.
