Sometimes it's beyond my comprehension ...
Why this if, else if and else condition is always TRUE (on the first if()) as said my CW compilator :
U8 isInPeriod(U8 mm_start, U8 hh_start, U16 dly_run)
S16 rtc_mm_time;
U16 total_mm_start;
U16 total_mm_stop = 0xFFFF;
rtc_mm_time = u8RTC_minutes + (u8RTC_hours * 60);
total_mm_start = mm_start + (hh_start * 60);
total_mm_stop = total_mm_start + dly_run;
if(0 <= total_mm_stop && total_mm_stop < 1440)
if(total_mm_start <= rtc_mm_time && rtc_mm_time < total_mm_stop)
return YES;
else
return NO;
else if(1440 <= total_mm_stop && total_mm_stop < 2879)
rtc_mm_time = rtc_mm_time - total_mm_start;
if(rtc_mm_time < 0)
rtc_mm_time = 1440 + rtc_mm_time;
total_mm_stop = total_mm_stop - total_mm_start;
total_mm_start = 0;
return YES;
else
return NO;
else
return NO;
Because in plus, this function is doing the job properly ...
Thank you very much,
Sylvain
