Hi all, I have downloaded the AN3601 from this website.the title is "A Mine's Lamp using the MC9S08QG4". as the Application Note said:"The design details of this solution are available in source files. This solution can be easily customized to work with any high-illumination LED and battery..." . but i can't find its software. it is not shareable?
can anybody help me? thanks.
A good question. I am looking into this,
---Tom
We are also looking for the source code for the AN3601 application. Our project is using a QG4. This code would save us a lot of work. If you can get this to us we would really appreciate it.
Paul
Check your e-mail. I have tracked down the engineer and have sent you the source via e-mail. I am looking into why this archive was not visible on the site.
---Tom
Hey there Mr. Jedi master, some of us "lurkers", I'm sure, would like to also take a peek at this mysterious SW. Maybe some code from an ancient civilization or UFO technology! ;o)
Best regards, Bobmac
If you need it for a project, I'll e-mail it to you. Right now I'm trying to set it up so that the archive appears on the site along with its App Note so everyone can get at it, at any time.
---Tom
Hi Tom,
I came across AN3601 and I'm also looking for the source code for a new project I will be working on.
Is it available on the website (can't find)
or can you sent it to me by email??
thanks
Martijn
Check your e-mail, please. I just sent you the archive.
I am going to have to figure why this file is still not showing up. I apologize for the inconvenience.
---Tom
I got the source code some time ago from someone on the forum. Thanks for asking.
Paul
Can you please email the source code for this AN as well, please?
I tried sending the archive to the e-mail address in your registration and the mail server rejected it. I suspect it may not like the zip attachment.
---Tom
Tom - can you zip and change the file suffix to .abc instead of .zip?
Thanks!
I changed the file extension as you requested and after fifteen minutes without a rebound notification to my e-mail, I have to assume it got through. Let me know if it worked.
---Tom
Hi Tom;
I'm sorry, I couldn't help my self. A feeble attempt at a bit of levity. You did make the source of this code sound a little bit mysterious after all ;o)
Best regards, Bob
