Whats difference between S12ZVC 128kb , S12ZVC 192kb
akguen
I have s12zvc development kit. I ordered a new mcu from the Internet because the MCU unit is broken. But when I changed it, I realized that there was no voltage on pin adr-6. The old processor is 128kb and the new one is 192kb. Is there anything I need to fix about the software?
dianabatrlova
At first, I would like to check the concrete part number of both devices.
Can you share whole part numbers of the MCUs?
Thank you.
Diana
akguen
My trouble was due to my solder. My problem was solved, thank you for your interest.
