What is "LDHX #0x06B0"
1,687 次查看
kelvinNgai
Hi all,
I use the USB multilink to download the example code PER test RX to my devices successfully i think, anyway, after i click "run", it seems nothing happened, the PC register keep 1983 and the assembly window show me stop at "LDHX #0x06B0"
what happened to my device ?? i am confused.
Does it mean my programme doesn't work? what is the right way to use debugger of the code warrior, it seems help me nothing in my situation.
Thank you
Kelvin Ngai
标签 (1)
1 回复
675 次查看
peg
Senior Contributor IV
Hi Kevin,
The problem is not with th LDHX command as this should work properly in any context.
Your problem could be one of many things, one of which is an unhandled COP expiring at this many cycles into the programme.
