What is clock config on a PA4 when in debug mode?
CustomSarge
Having startup issue: when debug plugged in/running code executes fine.
Freestanding restart just loop restarts like the watchdog isn't being fed.
I've had this issue on other projects, and have a PA in one that runs fine.
Wondering if I'm in an odd clock speed and picking bad range parms for ADC & FTM.
If I can start from the debug clock mode, I should be able to find my way.
Right now it either runs under debug or loop restarts, with no good clue what's wrong.
This is a port-over from a QE that's been fine for 2+years, but the PA is a little different.
Any and all pointers Greatly appreciated, TNX, K.Sargent
Update: I'm configuring the chip wrong.
Reduced code to just port initialization, with a simple blink the LED loop and it runs fine.
At least I know it isn't in the hardware...
Still would like to know what modes/options the debug module enforces. TNX
Found problem, forgot the macro "feed_watchdog" blows up H:X.
P.S. who in hell would write a stock macro that blows up registers??
