Hi all
I want to connect an optical port with baud rate 300 to 1321x NCB board. But the board baud rate can only be set from 1200 to 38400. I added 300 baud rate to existing table (red lines). It works but receives bytes with error or some bytes are missed. What should I do now?
#ifndef gSystemClock_d
This does not deserve a new thread.
This should remain as a continuation of your original thread.
This way the whole story stays together for other searching in the future.
Perhaps a moderator could lock this one.
