Hi everyone,
I'm using the CodeWarrior V6.2 to program a MC9RS08KA2 (2 KB Flash).
I'm also using a "USB Multilink" of P&E Micro (www.pemicro.com).
When I choose "P&E Multilink/Cyclone Pro", the window "PEMICRO Connection Manager" is open and the first field to be choosed is "Interface".
My problem is: if I create a new project by choosing a uC of HCS08 family, I have in this field the option: "USB HCS08/HCS12/CFV1 Multilink - USB Port". In this case, the hardware is correctly detected by the CodeWarrior.
However, as I really need to create a new project by choosing the uC MC9RS08KA2, I don't have anymore the option above, but "USB HCS08/HCS12/CFV1 Multilink (Rev C or Later)".
In this case, my USB Multilink is not detected!!!
Please, does anyone know what I can do to have the USB Multilink detected in this case?
Thank you, in advance.
Cremonezi
解決済! 解決策の投稿を見る。
Dear cremonezi,
I supect that your BDM does not support the RS08 chips. These require a 12V supply for programming which is absent in the earlier versions of the P&E BDMs (before RevC?). Is your BDM this version?
I suggest you check the P&E website or contact them by email to check this.
bye
Dear cremonezi,
bye
Hi pgo,
Thank you very much for your answer.
I've contacted the technical support from pemicro.com and you are right.
I have actually a USB-ML-12 Rev B, which does not support the RS08 family.
Cremonezi
