One of the differences is that, H register is not stacked when control passes over from main to an ISR.
Hence if H is being used, it should be pushed and popped in an isr.
Raghu Sorab
Hi baonguyen,
The newer 08 is just an improved version of the older 05.
Take a look at AN1218.
Regards David
