TWR LCD
TWR LCD
971件の閲覧回数
piotrpeczek
Hi, I'm trying to load official .s19 demo to my MCF51JM128 but only white screen appears. I can't use BDM cable and my SW5 settings are all right. How to fix it?
タグ(3)
4 返答(返信)
705件の閲覧回数
DavidS
Hi Piotr,
Sorry for your difficulty.
When you plug in USB cable, it is enumerating as USB MSD?  Do you see "Bootloader mode: waiting for S19 file..." displayed on LCD?
If yes to both please try using my "precompiled S19" files to test your display.
Here is my sw1 configuration for reference:
David
705件の閲覧回数
marcinurbanski
Hi!
I have same problem. Your demos work great, but when I try to compile the latest demo from eGUIs package only white screen show up. I use CW 10.6. May I ask you to show us your source files (1 project would be enough to compare diffrences)? .
705件の閲覧回数
piotrpeczek
Thank you! This is very helpful, but only to regain bootloader. I want to design my own application using MCF51JM128, but as mentioned earlier Official Demo provided by CW10 results only in white screen ;/
705件の閲覧回数
DavidS
Hi Piotr,
I had to dust off some old old project files to find something that compiles with CW10.6 and is targeted for working with the TWR-LCD bootloader on the JM128.
Attached is ZIP.
Open the ",project" in the following path:
TWR-LCD Demo Projects\CW MCU 10\HelloWorld_MCF51JM_SPI_BL
Before you try to clean and build you can try the S19 file in the sub folder with respect to the above project path:
MCF51JM128_Internal_Flash\HelloWorld_MCF51JM_SPI_BL.elf.S19
Hope this helps.
David
