I bought an NTM88H155T from mouser and having dificulties attaining a datasheet. Does anyone know what the supply voltage range is? I would like to power the entire IC by a 1.8V VDD supply, would this work?
Solved! Go to Solution.
You can request datasheet by submit ticket,the VDD related parameter included in EC table datasheet:
