Spyder - data transfer to PC
2,648 次查看
genoa380
I am planning to use Softec Spyder as a temperature recorder, my problem is how to tranfer these data to PC through
USB, and if possible, usb software to PC-side, to record data in a usable file, xls for example.
Any other solution is welcome.
Thank you for your help.
7 回复数
2,103 次查看
Mickey
If you use the BKGD do communications, you can use FreeMaster; If you use the SCI, through FTDI chip.
2,103 次查看
genoa380
Thank you for your anwer,
I use BKGD
but could you be more explicit please
2,103 次查看
Mickey
the tool is cheap and easy can be found here.
USBDM
can support the latest freeMASTER v1.3.10.1 BDM communications.
2,103 次查看
Mickey
you can refer to freeMASTER page.
Here
spyder does not seem to support freeMASTER.
2,103 次查看
genoa380
Hello Mickey,
Looks great
Thank you so much.
2,103 次查看
Juls
if you wish USB choose a JM series or a serial to usb chip like ftdi does
for the pc side you have many choice there if you want something more clean you should build your own app to receive serial from a com port or directly from USB with winusb (see jm serie video tutorial)
if you need something fast just send text with your cpu and catch it with hyperterminal
2,103 次查看
genoa380
OK I will try Hyperterminal fist, and then probably my own app.
