Software SCI Receiver for MC9S08QG4 (8 Pin PDIP)
3,471 次查看
datamstr
Hi All,
I am looking for some 'C' code to do a Software SCI Receiver for the MC9S08QG4 (8 Pin PDIP).
The serial communication parameters are 9600,8,n,1. I only need to receive six bytes and there is no need to transmit serial data.
TIA,
David
5 回复数
1,339 次查看
RogerSchaefer
I have a short assembly subroutine for the 8 pin MC68HC908QT4 but you would have to adjust the timing loops for the different clock speed.
Roger Schaefer
1,339 次查看
fabio
There is a full functional example showing how to do this in my book: HCS08 Unleashed . You can also download the examples at: www.sctec.com.br/hcs08.
1,339 次查看
datamstr
Hi Fabio,
I looked at the code examples from your book, but do not see a Software SCI Receiver.
Can you please point that out to me?
David
1,339 次查看
fabio
Example 9.15 shows how to implement a bitbanged SCI (both TX and RX sides) using one TPM channel for each side.
1,339 次查看
datamstr
Hi Fabio,
Thanks, I was looking through Chapter 11 instead.
David
