Hi, Baonguyen:
Even after you have written a one to TRST, it will always read back as zero. It does not hold the timer reset, but simply clears the timer instantaneously. If you need to, the TSTOP bit can hold the timer at reset until you clear TSTOP. This appears to be what you are doing by writing 0x30 to T1SC.
edit:
(: Oops, peg beat me to the post again
Message Edited by rocco on 05-23-200612:20 AM
