PWM configuration on PORT Pin:
1,798 次查看
nishasingh
Dear SUpport,
I am using your mc9s08pa16 device in 32 pin package.
I need 20KHz PWM on PTC4 & PTC5, which is difficult to do. Pls. guide me in overcoming my fault.
Attached here pls. find my sample test code for your reference.
Nisha
Original Attachment has been moved to: test_pwm_pa16.zip
标记 (3)
1,460 次查看
Robinwithu
Senior Contributor I
Hi Nisha,
Please go through  AN2616 in an attachment .Section 4.6 Describe how to generate PWM using Timer for MC9S08GB60 micro controller.I hope you will modify this code for your controller if not please let me know.
Thanks and Regards,
Robin
