Mixing ASM and C.Error:C18107: Illegal Operands
1,031 次查看
Tianshu
Hi:
     I'm trying to mix assember and C code in a c file:
interrupt void OSTickISR(){  OSIntEnter();  if ( OSIntNesting == 1 )  {     asm {       pshh;       tsx;       pshx;       pshh;       ldx OSTCBCur;       pshx;       ldx OSTCBCur+1; ; this line got ERROR: C18107       pulh;       pula;       sta 0,x;       pula;       sta 1,x;      }    }   OSTimeTick();   EnableInterrupts;   OSIntExit();}
 When I compiled this code, I got one error, ERROR: C18107: Illegal operands at the 11th line. I have define OSTCBCur as a pointer. Why do I get this error?  Thank you.
 Beset regards.
Liu Yu
700 次查看
bigmac
Specialist III
Hello Liu Yu,
Inline assembly code has some syntax differences from normal assembly code, found in an asm file.  Try
    ldx OSTCBCur:1;
Mac
701 次查看
bigmac
Specialist III
Hello Liu Yu,
    ldx OSTCBCur:1;
Mac
700 次查看
Tianshu
Hello Bigmac:
        I have solved my problem. Thanks for your help!
        Best  Regards.
Liuyu
