MC9S08QG8CPBE is EOL in stores, active in NXP !!!
3,524件の閲覧回数
tonyp
Senior Contributor II
There is a last buy note for
MC9S08QG8CPBE
935322628174
Active
Last Buy Date: 22-May-2020
Last Delivery Date: 22-May-2021
although it appears as Active.
The note was issued recently (2019-11-22) but shouldn't it first go into "Not Recommended for New Designs" status?
And once there is a "last buy date" set, shouldn't the item automatically stop showing as "Active"?
Someone may start a new design on it, and by coming June there won't be any chance to order it.
This particular chip is an example I happened to notice that does not affect me directly.
However, what truly bothers me, is the possibility that a whole bunch of other chips that I currently use can suddenly have the same fate without enough warning, you know the "Active" => "Not recommended" => "Inactive" sequence with plenty of time between status changes.
Can this situation be corrected?  How about the Product Select page shows the actual status, and not a deceiving one?
5 返答(返信)
3,265件の閲覧回数
rail21
Hi again Vicente and my apologies, I should have read my last reply before I posted it.
The IC I meant to enquire about and hope to use as a replacement for the above IC is actually the MC9S08SH8CPJ. Is there any intentions to suspend production of this IC in the near future?
3,265件の閲覧回数
vicentegomez
For the MC9S08SH8CPJ  is still available and there is not information about  end of life
the only change is
201904029F01:20PDIP Assembly Site Transfer to TFME from ATP1
3,265件の閲覧回数
rail21
Hi Vicente and I too am somewhat disappointed in the short time to EOL of the MC9S08QG8CPBE chip.
I can change to the MC9S08SH8CPJ chip but this means new PCBs have to be made.
Before I start the change, is there any idea of an EOL date for the MC9S08QG8CPBE chip?
3,265件の閲覧回数
vicentegomez
3,265件の閲覧回数
vicentegomez
I have already informed the web team to update the status of those parts on the web page. They will update on the next days.
Regarding the discontinuation, this is a marketing desition, al help you to past your comments to the product marketer. Unfortunately, the DIP package is dying, not only on 8 bit, in all technologies.
