MC9S08QE4 not running with external crystal
soli255
Hello, I have a problem with running my QE4 with external crystal (I have tried 11.0592MHz / 8MHz / 4MHz - different packages and manufacturers)
My code:
  ICSC2_BDIV     = 0b10;
  ICSC2_RANGE    = 1;
  ICSC2_HGO      = 1;
  ICSC2_LP       = 0;
  ICSC2_EREFS    = 1;
  ICSC2_ERCLKEN  = 0;
  ICSC2_EREFSTEN = 0;
while ( ICSSC_OSCINIT == 0 );
  ICSC1_CLKS     = 0b10;
  ICSC1_RDIV     = 3;
  ICSC1_IREFS    = 0;
  ICSC1_IRCLKEN  = 0;
  ICSC1_IREFSTEN = 0;
Problem is that program freez on while condition - crystal is not running. I use standart connection to XTAL and EXTAL pins with 22p capacitors and 1MR resistor.
Any suggestion what is wrong?
Thx
soli255
I just run my QE with 6MHz crystal in FBELP mode by this code:
// *** FBELP MODE ***
  // 6MHz Crystal
  // Fbus = ( Fext * 1 / BDIV ) / 2
  ICSC2_BDIV     = 0b00;  // selected clock / 1
  ICSC2_RANGE    = 1;     // high range select
  ICSC2_HGO      = 0;     // low power
  ICSC2_LP       = 1;     // FLL disabled
  ICSC2_EREFS    = 1;     // oscillator request
  ICSC2_ERCLKEN  = 0;
  ICSC2_EREFSTEN = 0;
  for ( i=0 ; i<1000 ; i++ );
  //while ( ICSSC_OSCINIT == 0 );
  ICSC1_RDIV     = 0b111;  //
  ICSC1_IREFS    = 0;
  ICSC1_IRCLKEN  = 0;
  ICSC1_IREFSTEN = 0;
  ICSC1_CLKS     = 0b10;  // external reference clock selected
I am still quite confused by this many modes of operation, and fact that in FBELP mode BDC should not be active, but I have full functional debuging (code step, breakpoint, periodical RAM readouts ...)
bigmac
Specialist III
Are you attempting to use FEE mode or FBE mode - there is some ambiguity?
For FEE mode and RDIV setting of 3 (reference division by 256), only the 8 MHz will work.  A lower division setting would be required for the 4 MHz crystal.  The 11.0592 MHz crystal is unsuited to FEE mode.
You could also try commenting out the wait loop for the OSCINIT flag.
Mac
soli255
Hello Mac,
I am following the "Using the Internal Clock Source (ICS) for the HCS08 Microcontrollers" chapter in HCS08QRUG.pdf and I was trying to run in this FBE.
I was also using wait loop like this for ( i=0 ; i<10000 ; i++ );
And also I modified my layout and move 22p capacitors very close to crystal and each other.
But franklly i will be glad for any mode runnig with crystal - because i already try several crystals and many of code.
Thx
soli255
I just finish working on QE with 32,768kHz crystal, but another fail. Code for FEE and 32kHz here:
// Fbus = ( Fext / RDIV * 512 / BDIV ) / 2
  ICSC2_BDIV     = 0b01;  // selected clock / 2
  ICSC2_RANGE    = 0;     // low range select
  ICSC2_HGO      = 1;
  ICSC2_LP       = 0;
  ICSC2_ERCLKEN  = 0;
  ICSC2_EREFSTEN = 0;
  //for ( i=0 ; i<10000 ; i++ );
  ICSC1_RDIV     = 0;     // div by 1
  ICSC1_IREFS    = 0;
  ICSC1_IRCLKEN  = 0;
  ICSC1_IREFSTEN = 0;
  ICSC1_CLKS     = 0b00;  // output from FLL
my QE is still without clock from external crystal ...
soli255
  // 6MHz Crystal
  ICSC2_ERCLKEN  = 0;
  ICSC2_EREFSTEN = 0;
  ICSC1_IREFS    = 0;
  ICSC1_IRCLKEN  = 0;
  ICSC1_IREFSTEN = 0;
