MC9S08PL32CLD mask 4N40C we need support
galahad
We desperatly need any available information about this mask set, so that we can deside if it makes sense to us to continue with this mask set - or send the whole batch back to rochester. I guess they would get the infomation, because it seems that they have a lot more of this easter eggs in stock !
vicentegomez
What kind of information do you need?
you can find the errata on the next link
https://www.nxp.com/docs/en/errata/S08PT60_4N40C.pdf
galahad
We know this errata - but it is NOT for the S08PL32, but only PT and PA variants.
Our MC9S08PL32CLD mask 4N40C has a different pinning, not the pinning described in the current data sheet MC9S08PL60 Rev.4 06/2020
Hard to believe, but true. Could you please look in your records for:
- a MC9S08PL32CLD mask 4N40C errata
- older data sheet revisions that cover our version, date code 1231, lot MEA1830200, still sold by rochester
Thank you very much, any help  appreciated!
vicentegomez
I could not find any information that the PL has the mask set 4N40C maybe is because this is too old, would be possible that you send me a picture of the device
galahad
They were sold as MC9S08PL32, on the chip you can read M9S08PL32, maybe that makes a difference... Hope that helps!
vicentegomez
Please give me some time to check it
regards
vicentegomez
I got the confirmation that you can use the errata for the PT family (mask set 4N40C) for the PL family mask set 4N40C
I hope this will help you
have a good day
galahad
Thank you very much!
And what about the different pinning? Can you at least confirm? Any older data sheet available that cover this mask set?
vicentegomez
I have already shared some information from the data sheet rev 0.
Vicente
