This is a discussion in behalf of anny li
I have a problem to set up the SCI port on the MC9S08PA4. Can someone help me?
已解决! 转到解答。
Hi Anny Li
I have attached a CodeWarrior v10.3 sample code that set the SCI2 at 9600, I use the SCI due this is the OSBDM. You only need to change to the SCI0
I hope this will help you.
