MC9S08AW32 intermittent loss of clock status.
kevingordon
I am getting a loss of clock status.  The processor resets with the "LOCS" bit set.  It occurs intermittently.  The ICG clock module is configured as follows:
   ICG Conrol register (ICGC1) 1111000
      - HGO set for high gain oscillator HGO =1
      - Range set for high frequency range RANGE = 1
      - REFS set for oscillator using crystal REFS = 1
      - CLKS mode FBE (FLL bypassed, external reference) CLKS = 10
The external oscillator is a 2 mhz crystal, MCLK = 250khz
Anyone have any ideas why I'm getting the intermittent reset?
vicentegomez
Hi Kevin
do your product is on a noise environment?
Please check the following application note AN3208
Would be possible that you send me your schematics?
Vicente Gomez
