MC13234, How to make a PWM output?
已解决
跳至解决方案
2,176 次查看
Braulio_Cespede
Hi everyone.
I'm currently working on a project with the MC13234 (Zigbee Wireless micro-controller). I have to Implement a PWM  component output, but to be Honest, I don't even know how to make one.
Can someone help me?
With a Example I can make it through.
Thanks for Advanced.
标签 (1)
1 解答
2,017 次查看
iansmusical
Contributor V
Hello Braulio,
You'd probably be best looking at the TPM section of the MC13234 reference manual, assuming you understand what PWM is etc. Then have a look on the Freescale website for the HCS08QRUG document that shows a working example of using the TPM to generate PWM signals. Keep in mind that there are differences between TPM modules (and other modules) between some S08 variants.
Hope this helps :-)
Ian
在原帖中查看解决方案
3 回复数
2,018 次查看
iansmusical
Contributor V
Hello Braulio,
Hope this helps :-)
Ian
2,017 次查看
Braulio_Cespede
Thank you for answer, I'm already done it.
Anyway I want to learn more about it, so I will find those documents and study a little.
Thanks again.
2,017 次查看
Wlodek_D_
Senior Contributor II
Thank you for your post, however please consider moving it to the right community place (e.g. 8-bit Microcontrollers ) to get it visible for active members.
For details please see general advice Where to post a Discussion?
Thank you for using Freescale Community.
