ICDHCS08 & Win7
ICDHCS08 & Win7
819 次查看
tonyp
Senior Contributor II
Hi all,
I've already made a support request to P&E but since I'm in the middle of an urgent project, and I need to get this working asap.
Due to a PC replacement (old is malfunctioning, so I can no longer use it) I went from WinXP to Win7 (no choice, as WinXP is no longer available.)
Attempting to re-install ICDHCS08 gives several errors and aborts installation.  P&E's response as for the availability of an update is pending.  But, I need to work.  So, has anyone managed to get this program to run under Win7?
(Copying the raw files from a backup -- no installation -- seems to run but fails to see the Cyclone PRO).
TIA
648 次查看
Designer11
Tony,
I am not familiar with the program. But, you can  try to run the program in Windows XP mode under Windows Virtual PC
