I2C and Processor Expert
2,609 次查看
datamstr
I created a new QG8 project using CW 5.1. When I add the I2C Bean and change mode from "Master" to "Slave", I get an error message "This operating mode does not implemented yet". Is this true that "Slave" Mode is not supported in PE? Also, there is an inheritance error that comes up for the SCL and SDA pins.
David
787 次查看
mstrocka
You have probably selected "SW_I2C" bean, which uses general purpose pins and SW algorithm to generate IIC protocol(Master mode only). QG8 has also I2C peripheral module used by "InternalI2C" bean, which supports master mode and slave mode too.
787 次查看
datamstr
Yes, you are correct, that is what I did.
Thanks for your help!
David
