How to define the stop mode command? (S08DZ96)
1,101 次查看
mehdializadeh
I am using MC9S08DZ96 microcontroller and I using code warrior version 11. I want to put the MCU to sleep mode(STOP3). In the CPU settings, I have changed the sleep mode setting and the relevant registers have been activated.
I know with the asm stop; command MCU goes to sleep mode. But it doesn't work. I think this command:
#define StopMode {asm STOP;}
should be defined somewhere. Does anyone know how to define stop mode?
1,087 次查看
vicentegomez
I believe that you already solved the problem from your other thread
Vicente
1,078 次查看
mehdializadeh
Thanks a lot.
I am now in the process of trying to wake it up using  pin interrupt, LIN and CAN protocol.
Do you have any comments for this item?
1,071 次查看
vicentegomez
There are some applications note about CAN and LIN using the S08DZ,
please check
https://community.nxp.com/t5/8-bit-Microcontrollers/LIN-Bus-support-for-the-MC9S08PL-series/m-p/9241...
and you can download the CAN stack from
https://www.nxp.com/webapp/Download?colCode=MSCAN_S08&appType=license
I hope this will help you
