How to create a project including two targets in CodeWarrior
2,108 次查看
baonguyen
Dear everybody,
I want to creat a project including two targets in Metrowerk's CodeWarrior. How to do that? How to associate the code corresponding with each target ?
Thanks in advance,
882 次查看
fire
it's simple.
Click on target menu.
Choose one target.
go to project-->Create target.
here you can clone the target or create a new target.
if you are cloning you have to change the name twice in target settings.
then add the files required for the target.
you can remove the files from any target using project inspector.
Fire
