How can i be sure ICG is Off in Stop mode 3 ? - MC9S08AW16
1,770 次查看
PatrickP
I use a MC9S08AW16 with a battery and programmed it with BDM.
My program use Stop mode 3. I want to be sure that the ICG is OFF. (ENBDM in BDCSCR is 0).
If i correctly understand the datasheet, if BDM is plug when MC9S08AW16  turn on, ICG is on.
But when i unplug BDM do ICG be off or do i need to realize a reset on the MC9S08AW ?
Patrick
Added p/n to subject.
Message Edited by NLFSJ on 2008-10-03 07:07 AM
911 次查看
PatrickP
Thanks a lot !
Patrick
911 次查看
BasePointer
After unplug the BDM pod, you need a reset to disable ENBDM.
