High-Address into the accumulator in asm using only LDA
663 次查看
Brax02
I have declare a table like that.
ABC:                DC.W  $1234
The address of ABC is in my example 0xF200
I want to load in the accumulator 0xF2 only using a LDA command.
LDA  #ABC==> A=0x0, 0x0 is the LSB of the address and not the MSB of the address 0xF2
How can i do that ?
for sure I can do something like but it's not the goal.
          LDHX #ABC  ; HX = F200
          PSHH
          PULA          ;A=0xF2
516 次查看
implicit
I believe you want to use the HIGH operator in this case, at least for CodeWarrior's built-in HCS08 assembler.
E.g.
LDA #HIGH(ABC)
517 次查看
implicit
E.g.
LDA #HIGH(ABC)
516 次查看
Brax02
I was exactly looking for that ! Thanks a lot !!
516 次查看
bigmac
Specialist III
The following alternatives should also work -
   lda #(ABC/256)
   lda #(ABC>>8)
The calculation is done during assembly.
Mac
