Emulate ft245 with hcs08 is it possible?
1,070 次查看
elettronicarewo
Hi! i've an old application that use ft245 for usb connection; i'd like change it with another component, because my costumer report some fault; Can I use an HCS08 device like jb or js family for emultate ftdi device? it's possible use libusb driver instead to ftdi driver and make work again the application or i need to design again also the pc sw application for work with hcs?
824 次查看
david_diaz
In this case I recommend the Flexis JM board with SD Card drivers and USB connectivity, DEMOFLEXISJMSD.
Please find more information at:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=DEMOFLEXISJMSD
Hope this information will be useful for you.
Have a great day.
David
