Cyclone PRO meet ERROR $00000007 when downloading MC9S08PA32 with SAP mode
5,428 次查看
lukegu
Hi Dear ,
      One Customer uses the tool --- Cyclone PRO ---, for programming the device MC9S08PA32, with SAP mode .
 receiving an ERROR $00000007 which corresponds to "cannot enter debug mode" from the tool's manual.
The have other one piece , and it works well .
   So could you kindly help me to check the reason for this issue ? The setting of the PC terminal is attached .
   Thanks a lot !
4,000 次查看
mfugere
Have you contacted the customer support at PEMicro.com?   They do have telephone and web-forums help groups to obtain information on the PEMicro products.  They have been helpful to me in the past.
I do not know what this error code could mean, but it might be that there is something in the filename with those special characters that the software does not like.  But, the PEMicro tech support group should be able to provide help on the Cyclone error codes.
Best of luck!
