Can JM60's S08ACMPV2 be used as a linear amplifier?
1,536 次查看
z_george
868 次查看
ok2ucx
No, at least not as a standard opamp. The external signal ACMPO is a digital output, so it tends to slip either to Vdd or Vss depending on the actual analog level of ACMPO (internally). Thus you can't close the feedback via standard resistor network.
I've tested that, also wanted to use that opamp similarly.
Pavel
869 次查看
ok2ucx
Pavel
868 次查看
z_george
Hi Pavel, thanks a lot for your information. I guess I mixed the MJ60 ACMPOV2 with Operational Amplifiers on MSP430Fxx. – The on chip Amplifier is useful especially for sensor applications.
