Can Ext Clk in GB60 be 203KHz?
1,156件の閲覧回数
admin
Specialist II
The external frequency spec for the ICG in the GT/GB chips say 32-100Khz or 2-10MHz. But if I'm not using it as a reference for the FLL, is there any reason I can't apply a 203KHz clock here for use by the RTI?
From what I can tell it should work fine, but has anyone actually done something like this and lived to tell about it?
794件の閲覧回数
AndrewCulpepper
Hi.  I've not done it but the datasheet says that you can use a 0-40MHz external clock if the FLL is bypassed.
Andrew
