C2450: Expected: ; = ,
1,730 次查看
fabian_lanzini
I'm trying to compile a part of a program that should work normally but I don't understand why this error appear.
It should be a very simple problem but I can't resolve it.
Here's the following code :
#ifndef _MC9S08DZ60_H
#define _MC9S08DZ60_H
typedef unsigned char   byte;     >>>>>    C2450: Expected: ; = ,
#endif
 Thank you for the help if someone has an idea
1,005 次查看
CrasyCat
Specialist III
Hello
Here I would suggest you to generate the preprocessor listing for of the C source file where you get the message and check how the macro are expanded.
Byte might be defined differently some other place.
CrasyCat
