Application of mkl16z128
1,095件の閲覧回数
lisong_zhong
MKL16Z128,Two I / O ports are set as output function, and a diode (1N4148) is connected between the two I / O ports. It is found that the I / O port corresponding to the cathode is set at low level, and the other anode is set at high level, which will cause reset. Is this normal?
2 返答(返信)
991件の閲覧回数
diego_charles
Hi lisong.zhong@ohosure.com
I hope you are doing well.
 I´m investigating the issue.
To help you further could you let me know the following information.
  • Which I/O pins have you tested?
  • There is no other circuitry related?
  • Current draw by the diode
  • Do you have a custom board?
Best regards, Diego.
991件の閲覧回数
diego_charles
Hi, lisong.zhong@ohosure.com
Were you able to check the inquiries on my previous  reply ?
Please let me know any inconvenience.
