Yes it can... Only thing is you can only have one master and GZ60 are designed to be Master as they have a XTAL/Quartz and therefore a precise clock.
But if you compile the slave nodes as slave, no reason to have any problem.
If trouble in having GZ60 compiling as slave, take inspiration from GR60 as memory maps are equivalent.
Cheers,
Alvin.
