I am using a K4 processor with buf4.2. When trying to list breakpoints the processor stops after listing only breakpoint. At first I thought I was doing it wrong,but I tried buf34 on a EVB Board and it worked like I expected. It listed any number of breakpoints that I tried.
Is any one familar with the K4 processor with buf42 that may help with this problem? The only problems I have run accross with buf42 has to do with breakpoints. After stoping a point and then using P to continue ,the processor goes somewhere but I dont know where.
I cant use buf34 because the port and ram addresses are different.
Thanks for any help
Don't know if Buffalo4.2 source code is available, but I Buffalo3.4 source code you may find here
http://forums.freescale.com/freescale/board/message?board.id=8BITCOMM&thread.id=615
What about modifying it for you needs?
