HDMI Audio Hotplug detection Issue on IMX6
vm18553
I've tried to test HDMI Audio hot plug detection on imx6 board. I'm using mainline-4.14 kernel version & DRM subsystem (drivers/gpu/drm/bridge/synopsys/dw-hdmi-ahb-audio.c)
I've verified following two cases
case a:
  • boot target
  • connect cable
  • play back (No Sound)
case b:
  • boot target
  • play back
  • connect cable (No sound )
Both, case a & case b are failing only working case is case c,
case c:
  • connect cable
  • boot target
  • play back (Can Hear sound)
  • disconnect cable
  • connect it back (Can hear sound)
Is this known issue?
Labels (3)
Tags (2)
joanxie
