Hi Indir,
it should be possible, but in this case you must have a driver for M4 to access eMMC and NXP does not provide such driver. With a driver you should be able to access directly to the memory to read/write raw data or you may use a file system.
Carlos
NXP Technical Support
We did something similar using the M4 on the imx6sx but connected to a SD card reader (see SD Card interfacing from M4 via SPI). Points to note:
1. You may not be able to use DMA as this is controlled from the Linux side.
2. If A7 is in sleep mode then certain clocks may not be available or running at reduce speed which will effect data transfer rate.
Hi Indir,
Carlos
